GYam's avatar
GYam
letter of volatility GS108NA
Hello,
I'm looking for a letter of volatility for the GS108NA switch.  Can someone please send me a link.
Thanks.
  • GYam,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi GYam,
    Welcome to our community!
    Here is the certificate of volatility for GS108NA. No password needed. The link will expire after 48 hr period.
  • JohnC_V's avatar
    JohnC_V
    GYam,
    • GYam's avatar
      GYam
      Thanks John.  Exactly what i needed.
ProSupport for Business
