jnoose
Jun 04, 2018Aspirant
Letter of Volatility GS724T
Howdy, I know this has been solved elsewhere but all the links have expired. Can someone please send a new link to Letter of Volatility for the GS724T? Thanks,
Justin
- Jun 11, 2018
Hi jnoose,
No need for a specialized software to fully reset the switch. Resetting it to factory default would suffice and NETGEAR doesn't provide any specialized software in order for the switch to cleared out. Maybe it was just pointing to the Smart Control Center.
JohnC_V
Jun 04, 2018NETGEAR Employee Retired
Hi jnoose,
Welcome to our community!
Here is the latest letter of volatility for GS74T. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
jnoose
Thank you so much for the quick turn around on this! Follow up question - where would I find the "specialized software utility" to clear the non-volatile flash memory on this switch? In my environment, the switch either needs to be fully sanitized or destroyed.
- JohnC_VJun 05, 2018NETGEAR Employee Retired
Unfortunately, NETGEAR doesn't provide any "specialized software utility" in order to clear the non-volatile memory on their switch. Either you factory default it or destroy it on a different way :)
- jnooseJun 05, 2018Aspirant
Well, I wish the LoV would just say that, "restore to factory default settings" as well as a process to affect that change. Unfortunately, it says "Use specialized software utility". So, am I assume this switch can just NOT be cleared and must be physically destroyed?
- jnooseJun 11, 2018Aspirant
Hi John,
Still looking for some clarity on this issue. Do I NEED the specialized software to fully clear this switch or would a factory reset suffice?- JohnC_VJun 11, 2018NETGEAR Employee Retired
Hi jnoose,
