jnoose
Jun 04, 2018Aspirant
Letter of Volatility GS724T
Howdy, I know this has been solved elsewhere but all the links have expired. Can someone please send a new link to Letter of Volatility for the GS724T? Thanks,
Justin
- Jun 11, 2018
Hi jnoose,
No need for a specialized software to fully reset the switch. Resetting it to factory default would suffice and NETGEAR doesn't provide any specialized software in order for the switch to cleared out. Maybe it was just pointing to the Smart Control Center.
jnoose
Thank you so much for the quick turn around on this! Follow up question - where would I find the "specialized software utility" to clear the non-volatile flash memory on this switch? In my environment, the switch either needs to be fully sanitized or destroyed.
JohnC_V
Jun 05, 2018NETGEAR Employee Retired
Unfortunately, NETGEAR doesn't provide any "specialized software utility" in order to clear the non-volatile memory on their switch. Either you factory default it or destroy it on a different way :)
- jnooseJun 05, 2018Aspirant
Well, I wish the LoV would just say that, "restore to factory default settings" as well as a process to affect that change. Unfortunately, it says "Use specialized software utility". So, am I assume this switch can just NOT be cleared and must be physically destroyed?
- jnooseJun 11, 2018Aspirant
Hi John,
Still looking for some clarity on this issue. Do I NEED the specialized software to fully clear this switch or would a factory reset suffice?- JohnC_VJun 11, 2018NETGEAR Employee Retired
Hi jnoose,
- jnooseJun 12, 2018Aspirant
So, with regard to the NV memory on this switch.... the letter of volatility should say:
"Remove power. User a paper clip to press the factory reset button."
You're positive this will return the switch to an unclassified state???
If so, can we please have the letter updated to reflect this?
