bjgardas's avatar
bjgardas
Follower
Nov 29, 2017
Letters of Volatility
To whom it may concern,
I am looking for the letters of volitility for the following model numbers:
GS108
JGS524
I greatly appreciate any assistance with this matter.
  • Hi bjgardas,
    Here is the certificate of volatility for GS108 and JGS524. Letter provided are the latest hardware versions. No password needed. Link will expire after 48 hr period.
    Welcome to our community!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi bjgardas,
  • JohnC_V's avatar
    JohnC_V
    bjgardas,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
