LuisTopete
Dec 10, 2020Follower
M4100 commands vs Cisco commands on CLI
Hello, it must not be that difficult,
What are the M4100 (with sw 10.0.1.16) commands to configure the switch
if i configure these next commands on a cisco switch?
config# VLAN 20
...VLAN)#name VOICE
config#int range f0/1-24
...config if range)#switchport voice VLAN 20
switch#write
I would also like to know, if it is necesary, how to configure my port 48 as trunk to connect to my cisco router for a voice service?
I had a cisco switch working properly but I was recommended to try the M4100,
so far a little too different to configure.
I am just trying to setup a VoIP with 5 ephones (79xx) in my house network.
chances are I am going to connect to VoIP service provider.
Thanks in advance.
1 Reply
- Retired_Member
Hi LuisTopete
Welcome to Community!
On M4100, you can create VLAN and add member port with trunk mode by below CLI command:
(M4100)>en
(M4100)#vlan database
(M4100)(Vlan)#vlan 123
(M4100)(Vlan)#vlan name 123 voice
(M4100)(Vlan)#exit
(M4100)#(M4100)#config
(M4100)(Config)#
(M4100)(Config)#interface 1/0/1
(M4100)(Interface 1/0/1)#vlan participation include 123
(M4100)(Interface 1/0/1)#vlan tagging 123
(M4100)(Interface 1/0/1)#exit(M4100)(Config)#exit
(M4100)#saveFor more detailed infor, please refer to CLI Manual, click here (page 46)
Hope it helps!
Eric
