jaron11
Oct 27, 2020Follower
M4100-D12G Letter of Volatility
Can you please send us a Statement of Volatility or Letter of Volatility for the M4100-D12G? If you are unfamiliar with this type of document, it should contain the type and size of each memory insi...
- Oct 29, 2020
Welcome to the community! :)
I got your private message as well. Kindly download the Letter of Volatility of the M4100-D12G (GSM5212) switch on this link. The link will expire within 2-3 days.
If you were able to download it and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Oct 29, 2020NETGEAR Employee Retired
DaneA
