shoval_k92
Mar 09, 2023Aspirant
M4250-10G2F - SFP module recognized but link is down
Hello all, I'm new to this so please pardon the ignorance. I have an M4250-10G2F switch, I am connecting an SFP module - AVAGO AFBR-709SMZ . While in the terminal command "show fiber-ports o...
LaurentMa
Mar 09, 2023NETGEAR Expert
Hi shoval_k92 ,
Please send the tech-support file out of the switch (AV UI Diagnostics\Support Diagnostics) to us, sending an email to ProAVDesign@netgear.com with a link to this thread.
I'm afraid this module you mention is from FS and is 10G SFP+ transceiver. So, if you have a switch with 1G SFP ports it wouldn't work (you need 1G transceiver). But we will inspect your tech-support file!
A 10G SFP+ module needs a switch with 10G SFP+ port (M4250-10G2XF-PoE+ or GSM4212PX)?
shoval_k92
Mar 11, 2023Aspirant
Thank you for the help.
Can you please advise me regarding a compatible SFP transceiver?
- schumakuMar 12, 2023Guru - Experienced User
https://www.netgear.com/business/wired/switches/accessories/
Select SFP, so 1000Base-SX, -LX, and -T.
- shoval_k92Mar 12, 2023Aspirant
Thank you very much!
I ordered 1000BASE-SX (AGM731F).
