Era1993
Aug 18, 2021Aspirant
M4250-16XF witch copper AGM734 not working
Hello. I have a M4250-16XF switch. In the first 12 ports I have compatible AGM731F fiber modules and they work fine. In the last ports I have put copper AGM734 modules, but none of them work. I hav...
- Aug 18, 2021
None of all these questions apply. According to the M4250 series AV Line Managed Switches Datasheet, p.28 "GBIC SFP and SFP+ Optics for M4250 series":
"M4250-16XF (XSM4216F) supports AGM734 on its ports 1 to 12 only."
Consider to redesign the port usage accordigly, re-locating the AGM734 to lower port numbers 8-)
schumaku
Aug 18, 2021Guru - Experienced User
Era1993
They are already working.
It's just like you said.
Finally, the problem was that these modules can only be in the first 12 ports and I was testing from 13 to 16, because in the first I had Fiber modules.
The fact is that even a Netgear Support technician was connected to review it and did not know that detail.
Thank you very much for your help
