koralle
Feb 15, 2020Tutor
M4300 24X: sudden restarts
Hi, i have since months sudden restarts with a M4300-24X (Firmware 12.0.9.3) in a single router setup. I use mostly LAGs with 2 ports for every system (Layer3+4 mode) and has disabled the most defa...
koralle
Feb 18, 2020Tutor
Hi,
the switch has restarted after 2-3 days uptime after the reboot for the new firmware. The new firmware 12.0.9.4 has no positive effect.
The CPLD-Update from the Netgear Support has also no effect (no higher fan speed, which should be the result with this update). In my opinion was this CPLD-patch already included in the firmware (12.0.9.3) because the CPLD Version hasn't changed from 0x5.
Again no crash-log and only booting messages on the debug console with a cold start message.
I will try to replace this switch and hope that the next switch is more stable.
Best Regards,
Ralf
