koralle
Feb 15, 2020Tutor
M4300 24X: sudden restarts
Hi, i have since months sudden restarts with a M4300-24X (Firmware 12.0.9.3) in a single router setup. I use mostly LAGs with 2 ports for every system (Layer3+4 mode) and has disabled the most defa...
wuebra
Mar 04, 2020Aspirant
i have the same issue in a Stack mode with 2 m4300-x24...
reboots after 10-15 days and 1 reboot after 18 hours.
This is not acceptable for an enterprise product.
Netgear fixes the bug !!!
- kevin_hongMar 04, 2020Apprentice
Hi wuebra ,
Could you please privode the tech support file to me? i will try re-created the issue and it will be helpful to find out the issue root cause .
How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderators
Thank you
- wuebraMar 14, 2020Aspirant
kevin_hong wrote:Hi wuebra ,
Thank you
What kind of crap does support take off?
The support simply closed my case!
The switch restarted tonight. Syslog logs are available- wuebraMar 18, 2020Aspirant
suddenly nobody says anything!
The support blames each other.
The fact is: I have 3 switches, 2 of them are broken (6000 €) and I don't have a CPLD patch either
