rEdz3
Jun 29, 2021Follower
M4300 52 does not restart after a reboot
Hello Guys,
Im confronting to a problem since this morning.
One of my stacked switch (member) does not boot anymore after a reboot, when I connect to the console port it says some error :
The system is restarting due to the inconsistent state -704249856 in file: cardmgr_util.c line 1093
I suspect a flash corruption ... and it chain reboot..
I obviouly dont have access to the web gui or cli, just to the menu that able to delete some configuration but nothing change.
Can you guys help me with this ?
Thank you
1 Reply
- JohnC_VNETGEAR Employee Retired
Welcome to our community! :)
May I know what else have you done before anything happens to the CLI? It seems that the flash is corrupted on your switch. I suggest open a ticket on NETGEAR support and please let them know the status of your switch. Just in case the device is still under warranty, an online replacement will be provided.
John
NETGEAR Community Team
