warsawtech
Jun 24, 2019Tutor
M4300-8X8F Latest firmware 12.0.7.15 cause fan light to go to amber
I've already filed a case on this, but was curious if anyone else had seen this issue. Purchased new M4300-8X8F, and wanted to upgrade firmware from 12.0.6.7 to 12.0.7.15. After uploading and bootin...
- Jun 24, 2019
Check if your fans spin on firmware < 12.0.7.15, if so everything is quite OK. Apparently* that is due to a change in 12.0.7.15 that allows the silent operation of the M4300-8X8F until a certain temperature is reached.
However the fan LED indicators don't consider that change yet and and thus light up amber (falsely indicating a fan fault). LaurentMa explains the behaviour in this thread here: Feature request : M4300-8X8F - Allow force fans on (quiet mode or rack mode)
* Since I don't operate any M4300-8X8F for an actualy check, but the slightly bigger -12X12F
msi
Jun 24, 2019Luminary
warsawtech
Jun 25, 2019Tutor
Thanks for the clarification. I really appreciate the info
