IDale
Mar 31, 2020Aspirant
M4300-8X8F Management VLAN Configuration
I need to change the IP address and VLAN details set under "IPv4 Management VLAN Configuration" under System-> Management Interfaces. Currently in this section it has Route Mode set to ENABLED. T...
JohnC_V
Apr 01, 2020NETGEAR Employee Retired
Welcome to our community! :)
Once this IPv4 Routing is disabled, you will no longer access the management IP of the switch and you can only configure it via console.
John
NETGEAR Community Team
IDale
Apr 01, 2020Aspirant
Ok Thanks for the information.
Ian
