aps_Tech
Mar 31, 2022Follower
M4300-8X8F Vulnerabilities
We are seeing various vulnerabilities on both our M4300's with firmware 12.0.15.7 Port 8443 - SSL Certificate Signed Using Weak Hashing Algorithm Port 8443 - Sweet32 Port 80 - JQuery 1.2 < 3.5....
schumaku
Apr 01, 2022Guru - Experienced User
Please use seach.
The 8443 port issue is known, fixes are in the works.
Most vulnerability Scanners only check the jQuery version - and not for effective vulnerabilities. LaurentMa can we have a status of that part please?
- msiApr 20, 2022Luminary
For the record: It looks like all mentioned issues have been addressed with 12.0.17.6 including the upgrade to jQuery 3.6. For the issues related to the API port 8443, here is an extract using testssl.sh I've I ran against our "canary" switch I upgraded before upgrading all our M4300 to this new version.
./testssl.sh ip-or-fqdn-of-switch:8443 [...] Testing server's cipher preferences Hexcode Cipher Suite Name (OpenSSL) KeyExch. Encryption Bits Cipher Suite Name (IANA/RFC) ----------------------------------------------------------------------------------------------------------------------------- SSLv2 - SSLv3 - TLSv1 - TLSv1.1 - TLSv1.2 (no server order, thus listed by strength) xc030 ECDHE-RSA-AES256-GCM-SHA384 ECDH 256 AESGCM 256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 xcca8 ECDHE-RSA-CHACHA20-POLY1305 ECDH 256 ChaCha20 256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 x9d AES256-GCM-SHA384 RSA AESGCM 256 TLS_RSA_WITH_AES_256_GCM_SHA384 xc02f ECDHE-RSA-AES128-GCM-SHA256 ECDH 256 AESGCM 128 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 x9c AES128-GCM-SHA256 RSA AESGCM 128 TLS_RSA_WITH_AES_128_GCM_SHA256 TLSv1.3 - [...] Testing vulnerabilities [...] SWEET32 (CVE-2016-2183, CVE-2016-6329) not vulnerable (OK) FREAK (CVE-2015-0204) not vulnerable (OK)I can confirm that testssl.sh on port 8443 reports more and (and outdated) ciphers on previous versions and shows the SWEET32 as vulnerable.
