WireJunkie
Oct 03, 2022Tutor
M4300 switches, How to prevent a device with duplicate IP of gateway on the network ?
Is there a way to prevent anyone connecting into the switch with the same IP as the Firewall Gateway? for example if the gateway firewall Lan IP is 192.168.50.1 and a user comes along with a lapto...
WireJunkie
Oct 04, 2022Tutor
No its not work laptop. Basically we are trying to prevent anyone from Self-Assigning themselves the gateway IP of the firewall. So if someone comes in with a laptop, connects to the switch with the SAME IP as the GATEWAY, than the switch should KNOW that the TRUE gateway IP is on Port 5 instead of the laptop port 20. Its more to do with security than dhcp in my opinion. thoughts?
Marc_V
Oct 04, 2022NETGEAR Employee Retired
- WireJunkieOct 04, 2022Tutor
What about IP Source Guard, will that work with our scenario?
- Marc_VOct 05, 2022NETGEAR Employee Retired
You can also enable IP Source guard but the important one is using DAI.
HTH
