MasterPhil
Apr 14, 2019Tutor
M4300 VLAN ACL
Hello,
Im going to configure some VLANs on a M4300. Out Network will be designed as Spine-Leaf. While the M4300 is routing the VLANs, the S3300 models are for connecting the clients to the network....
DaneA
Apr 18, 2019NETGEAR Employee Retired
Hi MasterPhil,
I inquired your concern to the higher tier of NETGEAR Support and got a feedback today. As per the higher tier of NETGEAR Support, you can use extended ACL’s with TCP Flag. As reference guide, kindly read pages 172-186 of the M4300 user manual here on how to configure it.
DaneA
NETGEAR Community Team
- MasterPhilApr 19, 2019TutorThank you, But did Not work for us. Have the same problem like the guy in this case:
https://community.netgear.com/t5/Managed-Switches/M5300-oneway-VLAN-Routing/td-p/1673558
We do not want to bind to ports but to vlans. We have a dozen switches and vlans routed via a stack of M4300. So there are only vlan trunks to all edge switches.
