MasterPhil
Apr 14, 2019Tutor
M4300 VLAN ACL
Hello,
Im going to configure some VLANs on a M4300. Out Network will be designed as Spine-Leaf. While the M4300 is routing the VLANs, the S3300 models are for connecting the clients to the network....
DaneA
Apr 18, 2019NETGEAR Employee Retired
Hi MasterPhil,
I inquired your concern to the higher tier of NETGEAR Support and got a feedback today. As per the higher tier of NETGEAR Support, you can use extended ACL’s with TCP Flag. As reference guide, kindly read pages 172-186 of the M4300 user manual here on how to configure it.
DaneA
NETGEAR Community Team
MasterPhil
Apr 19, 2019Tutor
Thank you, But did Not work for us. Have the same problem like the guy in this case:
https://community.netgear.com/t5/Managed-Switches/M5300-oneway-VLAN-Routing/td-p/1673558
We do not want to bind to ports but to vlans. We have a dozen switches and vlans routed via a stack of M4300. So there are only vlan trunks to all edge switches.
