saranga
Dec 09, 2016Aspirant
M5300-28GF3 switch password reset ( switches are stacked )
I have two M5300-28GF3 switches , both switches are part of a Stack. How can I reset the password . I tried password recovery option via boot menu but no success. please help
DaneA
Dec 11, 2016NETGEAR Employee Retired
Hi saranga,
Welcome to the community! :)
Let me share the article below since it is applicable to the M5300 series switch. Let us know the results.
How do I recover the password for my managed Layer 2 and Layer 3 switch?
Hope it helps.
DaneA
NETGEAR Community Team
saranga
Dec 11, 2016Aspirant
Thanks Danea , I wil try this again and update the result.
- DaneADec 14, 2016NETGEAR Employee Retired
Hi saranga,
I just want to follow-up on this. Were you able to perform the instructions from the article I have shared to you? If yes, what are the results?
DaneA
- sarangaDec 15, 2016Aspirant
Dear DaneA
Thanks again for your follow up , I tried password recovery option via boot menu using rear panel DB9 port as per attached snap.But no success , i doubt that it because switches are stacked. Please guide me to recover the password.
- DaneADec 15, 2016NETGEAR Employee Retired
Hi saranga,
It would be best that you open an online case with NETGEAR Support with regard to your concern. Let them know about your concern and the troubleshooting steps you did so far for further assistance.
DaneA
