saranga
Dec 09, 2016Aspirant
M5300-28GF3 switch password reset ( switches are stacked )
I have two M5300-28GF3 switches , both switches are part of a Stack. How can I reset the password . I tried password recovery option via boot menu but no success. please help
saranga
Dec 11, 2016Aspirant
Thanks Danea , I wil try this again and update the result.
DaneA
Dec 14, 2016NETGEAR Employee Retired
Hi saranga,
I just want to follow-up on this. Were you able to perform the instructions from the article I have shared to you? If yes, what are the results?
DaneA
NETGEAR Community Team
- sarangaDec 15, 2016Aspirant
Dear DaneA
Thanks again for your follow up , I tried password recovery option via boot menu using rear panel DB9 port as per attached snap.But no success , i doubt that it because switches are stacked. Please guide me to recover the password.
- DaneADec 15, 2016NETGEAR Employee Retired
Hi saranga,
It would be best that you open an online case with NETGEAR Support with regard to your concern. Let them know about your concern and the troubleshooting steps you did so far for further assistance.
DaneA
- DaneADec 18, 2016NETGEAR Employee Retired
I just want to follow-up on this. Were you able to open an online case with NETGEAR Support? If yes, let us know the progress of your online case.
DaneA
- DaneADec 22, 2016NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
- sarangaDec 24, 2016Aspirant
Hi
I couldnt contact online support to resolve issue.
Thanks
