Arnaud_D
Dec 07, 2021Aspirant
M5300-52G3 11.0.0.37 firmware - SDM Question
Good Morning,
I'm in the process of upgrading all my switches and questions for some models.
I did read this on 11.0.0.37 :
SDM changes on M5300:
Maximum number of allowed VLANs changed from 4K to 1K in the default SDM (dual-ipv4-and-ipv6 data-center-enterprise) mode. If M5300 with 10.0.0 firmware has more than 1K VLAN, update from 10.0 to 11.0 removes all configured VLANs. Workaround: Manually reconfigure VLANs after the update.
The 4K VLAN is retained in SDM “Dual-ipv4-and-ipv6 enterprise” mode and “Ipv4-routing enterprise” mode.
When using the SDM with multicast, the following features are not supported. Workaround: Use other SDM template.
IP Source Guard
DHCP Snooping
Dynamic ARP Inspection
But I dont have the same SDM names in my switch, so I simply wanna be sure that the one I use is safe :)
Mine is currently IPV4 without Multicast, so I'm safe with the multicast part.
Also : The 1K vlan limit, does it means :
-the vlan list goes from 1 to 1024
or
-you can have 1024 vlans maximums (eeven with vlan id > 1024)
Thank you for your answer,
Hi
I did perform the upgrade so i dont need the answer anymore.
Thx
- Arnaud_DAspirant
Seems image is broken :
SDM list is :
Default
IPv4 Data Center Plus with IP Multicast Support IPv4 Data Center Plus without IP Multicast Support Dual IPv4 and IPv6 Data Center with IP Multicast Support Dual IPv4 and IPv6 Data Center without IP Multicast Support - Arnaud_DAspirant
Hi
Thx
