chawke's avatar
chawke
MS510TXPP + WAX625 - Multiple SSIDs & VLANs, only 1 DHCP working
Hi, I am trying to setup a SOHO network with the HW in the title, Multi-Gigabit Ethernet Smart Switches (MS510TXPP)  and Cloud Managed WiFi 6 (WAX620PA)    I have setup 4 VLANS 2 iot 3 guest 4 u...
  • Retired_Member's avatar
    Retired_Member
    Mar 29, 2023
    chawke
    No, you are not missing anything. It is the MS510TXPP that is missing a DHCP server or relay. It is hard to believe but unfortunately NETGEAR makes routing switches like that. The only way to have DHCP working for multiple VLANs on this switch is to have a DHCP server in each VLAN. I ended up buying another routing switch with a DHCP server support and using my MS510TXPP as a L2 switch.
ProSupport for Business
