chawke
Mar 29, 2023Aspirant
MS510TXPP + WAX625 - Multiple SSIDs & VLANs, only 1 DHCP working
Hi, I am trying to setup a SOHO network with the HW in the title, Multi-Gigabit Ethernet Smart Switches (MS510TXPP) and Cloud Managed WiFi 6 (WAX620PA) I have setup 4 VLANS 2 iot 3 guest 4 u...
- Retired_MemberMar 29, 2023
No, you are not missing anything. It is the MS510TXPP that is missing a DHCP server or relay. It is hard to believe but unfortunately NETGEAR makes routing switches like that. The only way to have DHCP working for multiple VLANs on this switch is to have a DHCP server in each VLAN. I ended up buying another routing switch with a DHCP server support and using my MS510TXPP as a L2 switch.
Retired_Member
Mar 29, 2023
chawke
Mar 30, 2023Aspirant
I am dumbfounded by this.
This is an EXPENSIVE piece of kit. Ok it has multigig interfaces and 10g uplinks on a PoE+, but still - what is the point of making it so full of features and then missing on this one.
Incredible... Thank you for the info, I marked it as a solution - hope it will help others.
