JLM_
Feb 11, 2016Aspirant
Multiple networks on same switch
Hi all, I would replace 2 switches with only one switch ( Netgear GS748Tv5 ). Actually the two switches are connected to 2 different routers, and there isn't a point of connection between th...
DaneA
Feb 11, 2016NETGEAR Employee Retired
Hi JLM_,
Welcome to the community! :)
I think it would be possible for as long as port-based VLAN would be configured on the GS748Tv5 and as well as VLAN is supported on the two routers.
DaneA
NETGEAR Community Team
JLM_
Hi DaneA, thank you for your reply.
Unfortunately i can't set up the VLAN on routers' side because they are managed from other people.
I thought can exist some actions to perform a sort of port isolation.....
