davidzz
Feb 08, 2023Aspirant
Net stats oid of M4300-8X8F ProSAFE 8-port 10GBASE-T and 8-port 10G SFP+
Hello l’m currently searching for the OID to get the net stat of a port on my M4300-8X8F ProSAFE 8-port 10GBASE-T and 8-port 10G SFP+ switch into the information system of the switch there is this o...
michaelkenward
Feb 08, 2023Guru - Experienced User
You have asked about switches in a section dedicated to routers.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- davidzzFeb 08, 2023Aspirant
Thanks 🙂
