ithardware
Jun 16, 2023Aspirant
Netgear GS724TP
Hi all, I have a Netgear GS724TP. I set it to factory default. if I plug a computer it get an IP, but if I plug an IP phone it does nothing. for some reason the IP phone is not connecting to...
ithardware
I didn't set any Vlan. everything is set to default. I don't see a Disable for the Vlan
schumaku
Jun 16, 2023Guru - Experienced User
This UI does not look like a GS724TP (dating from 2007) my friend. Probably more a GS724TPv2, the label might say something like GS724TP-200xxx?
- schumakuJun 17, 2023Guru - Experienced User
For what it's worth, Auto-VoIP and OUI-Based VLAN are disabled by default on the GS724TPv2. Worth to check the effective config in place first of course.
Here is the GS724TPv2 product documentation -> https://www.netgear.com/support/product/gs724tpv2#docs
