jkalber87
May 19, 2023Tutor
Netgear GS752TPV2 can't access web interface
Hello, I have a Netgear GS752TPV2 managed switch at one of the offices that I support. The issue I am having is I am unable to reach the web interface for this switch, but I am able to ping the swi...
HannesKannes
Jun 07, 2023Initiate
Hi,
The interface can only be accessed from the defined VLAN (by setup). So accessing PC must be inside this VLAN.
Furthermore the basic setting is HTTP to access the side. Please check the correct adress for HTTP and not HTTPS in the browser.
Best regards
Jan
jkalber87
Jun 28, 2023Tutor
Hello HannesKannes, that worked! When I typed in the IP address of the switch, it automatically threw the HTTPS:// in front of the IP address. I am now able to access the web interface by using HTTP:// instead of HTTPS://
Thanks for your help!
