AlphaGear
Mar 30, 2016Follower
NETGEAR Switch GS116Ev2 Password Login Reset / Switch Password Reset to Factory Default
How to reset the managed switch GS116E to it's factory default password ? I've tried all my best even the reset botton on the switch itself does not help. Please help!
omicron_persei8
Jun 19, 2016Luminary
You should try other versions of the Utility, more recent or older. I have read on this forum before that solved it, some kind of password encryption mismatch I presume.
At the time, the versions that the user tried were 2.2.36, 2.2.34 and 2.2.26 if I remember correctly.
Once done, update your firmware, change your password and update the utility.
