Mintman
Apr 10, 2018Aspirant
Network Archticture suggestions for large 3-Building apartment complex
We have 3 apartment buildings in a line, each with around 50 apartments over 4 or 5 floors each and we are looking to provide an internet connection to all apartments plus site CCTV: ‘Building A <—>...
- Apr 11, 2018
That's great! Well, that is a pretty good idea, so that the main router will not overload and you can even filter the LAN devices from it. If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Mintman
Apr 11, 2018Aspirant
Hi John,
Thank you so much for your reply - it is very much appreciated.
Why do you say that L2 may be sufficient "provided SFP is used"?
I actually have CAT6A already in ( :( ) so that they are capable of 10Gbps.
Why does SFP make a difference?
I like the idea of just taking a cable up to each apartment and just providing them with an ethernet socket that they can just plug their own switches into. That was actually my original idea until some other IT guy suggested we should put a router in each apartment!
Any thoughts on sub-netting? Is it even necessary or do you think VLANs will be sufficient?
Thanks John,
Derek
JohnC_V
Apr 11, 2018NETGEAR Employee Retired
If you already have a Cat6A cable, then, you may check our 10G Smart Managed Pro Switch Series. The SFP will not use the main ethernet ports on a switch and you can also use it for stacking.
May I know your plans why do they need to have a router on each apartment? Maybe he do have a purpose/other plans. If his purpose is just to provide another subnet, then the VLAN is sufficient on your setup and can do its job already as long as it is supported by a VLAN capable router. The VLAN router can also handle the VLAN routing.
- MintmanApr 11, 2018Aspirant
That's splendid!
I had in mind the 10G Smart Managed Pro series, but kept wondering if fully managed (L2/L3) was going to be desirable for reasons that I hadn't thought of!
I can't say we do have any firm plans yet. I'm just getting a feel for the various options. The only real reason for suggesting a router in each apartment was to control what devices tenants could attach directly to the site internet, possibly to stop people doing stupid things (eg attaching a switch port from their own router to the site system and thus trying to act as a DHCP server for the site - although a decent switch can ignore such requests from a rogue DHCP server, so I never really saw the relevance of it).
I think the 10G Smart Managed Pro Series and just using VLANs seems a relatively simple solution.
Cheers John,
Derek
- JohnC_VApr 11, 2018NETGEAR Employee Retired
