Mintman's avatar
Mintman
Network Archticture suggestions for large 3-Building apartment complex
We have 3 apartment buildings in a line, each with around 50 apartments over 4 or 5 floors each and we are looking to provide an internet connection to all apartments plus site CCTV: ‘Building A <—>...
  • JohnC_V's avatar
    JohnC_V
    Apr 11, 2018
    Mintman,
    That's great! Well, that is a pretty good idea, so that the main router will not overload and you can even filter the LAN devices from it. If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
    The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
