jjesson's avatar
jjesson
Network modeling
Is there a service that if I provided a network map would provide me with suggested switches for a mixed (i.e poe for voip and non voip for computers and smart tvs) home network?
  • JohnC_V's avatar
    JohnC_V
    Dec 23, 2017
    jjesson,
    Having an 802.3at switch will still be depending on how your network to be setup and depends on the devices that will be connected to it. Yes, you are correct. Even if the main switch is GS510TP which is a POE+(802.3at), the GS110TP will still remain the same running in POE(802.3af).
    I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
