rajivsingh
Dec 01, 2020Aspirant
Not able to creat DHCP pool
Dear Team i am not able to cretae DHCP POOL, i have already created few but suddenly its started giving error. Error:- Error! Failed to create DHCP Pool Firmware Version 11.0.0.18 ...
- Dec 03, 2020
Hi Eric
Thank you for the reply, we found that the switch has the limitation of 16 DHCP pool and we already utilized those limits that’s why it’s giving error.
Thank you once again.
Anonymous
Dec 03, 2020Hi rajivsingh
Welcome to Community!
Could you please share the configuration that you set for DHCP pool? By CLI command or Web GUI? And also pelase screenshot the error message that swtich popup. It's will be helpful to debug this problem.
Eric
- rajivsinghDec 03, 2020Aspirant
Hi Eric
- AnonymousDec 03, 2020
Hi rajivsingh
Corret, this switch only can support 16 DHCP Pool totally. So it's expected behavior that switch popup error message once you config DHCP Pool more than the maximum value.
Eric
