amudhan
Dec 07, 2016Aspirant
oid to monitor psu
Hi, I am trying to monitor Temperature, Power supply status in Netgear M7100-24X switch thru nagios. I am able to get temp out from switch in nagios but not able to get data for power supply. th...
DaneA
Dec 07, 2016NETGEAR Employee Retired
Hi amudhan,
Welcome to the community! :)
What is the current firmware version of the M7100-24X switch? You could download the respective MIB file that corresponds to the firmware version of the switch here.
DaneA
NETGEAR Community Team
- amudhanDec 08, 2016Aspirant
Hi DaneA,
My current firmware version is 11.0.0.12 and i have downloaded mibs file of same firmware, but i couldn't find information what i am looking for.
regards
Amudhan
- LaurentMaDec 08, 2016NETGEAR Expert
Hi Amudhan
It should be 1.3.6.1.4.1.4526.10.43.1.7.
We can see the power module with this OID through NMS300.
Please select table to show this OID via NMS300, and let us know how it goes!
Hi,
I have figured out oid, now i am getting below output.
check_snmp -H xx.xx.xx.xx -o .1.3.6.1.4.1.4526.10.43.1.7.1.3.1.0,.1.3.6.1.4.1.4526.10.43.1.7.1.3.1.1 -C xxxx -u 'PSU1,PSU2' -c @3:3,@3:3 -l "PSU status "
PSU status OK - 2 PSU1 2 PSU2 | iso.3.6.1.4.1.4526.10.43.1.7.1.3.1.0=2 iso.3.6.1.4.1.4526.10.43.1.7.1.3.1.1=2is this right?
I am beginer in monitoring switch thru snmp. so please help me on few basics.
Can you guide me how to browse mib files to find oid for an item. example temperature, psu, port Up or Down, ...
how do i confirm the oid is for the particular item monitoring.
regards
Amudhan P
