amudhan
Dec 07, 2016Aspirant
oid to monitor psu
Hi, I am trying to monitor Temperature, Power supply status in Netgear M7100-24X switch thru nagios. I am able to get temp out from switch in nagios but not able to get data for power supply. th...
LaurentMa
Dec 08, 2016NETGEAR Expert
Hi Amudhan
It should be 1.3.6.1.4.1.4526.10.43.1.7.
We can see the power module with this OID through NMS300.
Please select table to show this OID via NMS300, and let us know how it goes!
amudhan
Dec 08, 2016Aspirant
Hi,
I have figured out oid, now i am getting below output.
check_snmp -H xx.xx.xx.xx -o .1.3.6.1.4.1.4526.10.43.1.7.1.3.1.0,.1.3.6.1.4.1.4526.10.43.1.7.1.3.1.1 -C xxxx -u 'PSU1,PSU2' -c @3:3,@3:3 -l "PSU status "
PSU status OK - 2 PSU1 2 PSU2 | iso.3.6.1.4.1.4526.10.43.1.7.1.3.1.0=2 iso.3.6.1.4.1.4526.10.43.1.7.1.3.1.1=2
is this right?
I am beginer in monitoring switch thru snmp. so please help me on few basics.
Can you guide me how to browse mib files to find oid for an item. example temperature, psu, port Up or Down, ...
how do i confirm the oid is for the particular item monitoring.
regards
Amudhan P
- LaurentMaDec 08, 2016NETGEAR Expert
Hi Amudhan
Can I ask you a question before, are you using third party management software or command line for any reason?
We provide NMS300 Network Management System for your need, as everything is quite automatic - SNMP is used in background while you get nice Web interface accessible from anywhere in your network, and canned reports capability. Would you consider NMS300? This software is delivered free of charge up to 200 devices (and one stack of several switches accounts for 1 device only; while Access Points under a Wireless Controller don't count at all). Let us know if this monitoring solution could be useful for you instead. The download link is available under to Resources tab, or by clicking on the Get Support button.
