amit112214
Feb 01, 2018Aspirant
Password reset for GSM7248 Switch
Hi, I need to change password for Switch GSM7248 V2H1 . How can I do that?
JohnC_V
Feb 02, 2018NETGEAR Employee Retired
Hi amit112214,
In order for you to change the password, Go to Security > Management Security > Local User > User Management and follow the image below:
Here is the manual for reference(page 429).
- amit112214Feb 02, 2018Aspirant
Hi,
I am not able to go into this page because I dont know the root access means admin password.
- JohnC_VFeb 06, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VFeb 02, 2018NETGEAR Employee Retired
