Budgie4
May 23, 2020Tutor
Problem setting static IPs on M4100s
I am having difficulty setting static IPs on a pair of M4100 devices. It was my intention to set the static IPs within the same subnet and use Vlan 100, which is the vlan I am using for device management to facilitate communications within the subnet.
I sought to avoid a possible conflict by using sequential static IPs wihin the subnet but when I set the Vlan to 100 and try and save the configuration the default IPs reappear.
Can you help please?
- DaneANETGEAR Employee Retired
Kindly try to disconnect the M4100 switch from the existing network. Create VLAN 100 and select the port member/s you want. Select the port/s as untagged (U) with a PVID of 100. Then, go to System > Management > Management Interfaces > IPv4 Management VLAN Configuration. Change the Management VLAN to VLAN 100 and change the IP Address to the static IP Address you want to manage the switch.
DaneA
NETGEAR Community Team
- Budgie4Tutor
Hi and many thanks for the reply. I shall have to try whan I can disconnect but device is in use at present. Will find a good time to do this when it is quiet. Meanwhile things are working seemingly OK but I know not entirely correctly!
- Budgie4Tutor
Hi, I have just purchased a new and bigger switch as I had run out of ports with PoE etc.
Please could I re-visit this thread as I seek a little more help please setting up access ports for the management subnet.
I am trying to set up and work with a management subnet and vlan 100.
The management subnet with dhcp server is on one port of a Sophos UTM but I am trying to avoid having UTM involved with vlans, so and all the work is being done in the managed switch.
I have followed your earler advice on previous threads with the wireless bridge and setting up wifi access points (with 3 SSID & vlanned subnets) and the arrangment seems to be working well, for which many thanks, but I am less confident on how to proceed for the management of these devices. All devices have been given Vlan 100 management addresses but how should I set up the management address of the new managed switch so that I can manage all the vlan 100 devices, including the new switch from my own but different subnet?
