pryncypalki
Mar 24, 2019Tutor
Problem with full speed of GS110TP
Hello all,
I have a problem with the speed on the first port of the switch. I have to fix the speed to be able to see the device. If I will set the port speed to AUTO mode then the device is not vi...
schumaku
Mar 24, 2019Guru - Experienced User
Gigabit Ethernet is mandatory auto negotiation only. Tried a different port already?
What is making the connection to the "outside world"?
Fully fledged (eight strands/four pairs) CAT5E or better network cable to the "outside world"?
Current firmware in place -> https://www.netgear.com/support/product/GS110TP.aspx#download ?
- pryncypalkiMar 24, 2019Tutor
The infrastructure is quite complex (is a company). Let's say that I informed IT guys that I will connect the Switch to their switch and they gave me a fixed IP address, default gateway, broadcast IP, DNS servers, etc.
If I will go with the direct connection to their network (with the computer) everything seems to be ok. I have full speed etc.
I've used CAT6 cables
I've tried different ports.
I've the newest firmware 5.4.2.33
Maybe I'm missing something in the configuration.- schumakuMar 24, 2019Guru - Experienced User
Any corporate security on that uplink port probably?
No, I don't think so. It's really strange because I have got some unmanaged switches and those are ok. It is really annoying.
