pryncypalki
Mar 24, 2019Tutor
Problem with full speed of GS110TP
Hello all,
I have a problem with the speed on the first port of the switch. I have to fix the speed to be able to see the device. If I will set the port speed to AUTO mode then the device is not vi...
schumaku
Mar 24, 2019Guru - Experienced User
Gigabit Ethernet is mandatory auto negotiation only. Tried a different port already?
What is making the connection to the "outside world"?
Fully fledged (eight strands/four pairs) CAT5E or better network cable to the "outside world"?
Current firmware in place -> https://www.netgear.com/support/product/GS110TP.aspx#download ?
pryncypalki
Mar 24, 2019Tutor
The infrastructure is quite complex (is a company). Let's say that I informed IT guys that I will connect the Switch to their switch and they gave me a fixed IP address, default gateway, broadcast IP, DNS servers, etc.
If I will go with the direct connection to their network (with the computer) everything seems to be ok. I have full speed etc.
I've used CAT6 cables
I've tried different ports.
I've the newest firmware 5.4.2.33
Maybe I'm missing something in the configuration.
- schumakuMar 24, 2019Guru - Experienced User
Any corporate security on that uplink port probably?
- pryncypalkiMar 24, 2019Tutor
No, I don't think so. It's really strange because I have got some unmanaged switches and those are ok. It is really annoying.
- pryncypalkiMar 27, 2019Tutor
Today I've connected GS105 switch in between and now everything is fine. Anyways, is not really efficient to have a switch connected to the switch just because something is wrong with GS110TP. Do you maybe know what can cause the problem? The router that I'm connected with is HP PROCURVE 5406ZM J8697A R
