pryncypalki
Mar 24, 2019Tutor
Problem with full speed of GS110TP
Hello all,
I have a problem with the speed on the first port of the switch. I have to fix the speed to be able to see the device. If I will set the port speed to AUTO mode then the device is not vi...
pryncypalki
Mar 24, 2019Tutor
The infrastructure is quite complex (is a company). Let's say that I informed IT guys that I will connect the Switch to their switch and they gave me a fixed IP address, default gateway, broadcast IP, DNS servers, etc.
If I will go with the direct connection to their network (with the computer) everything seems to be ok. I have full speed etc.
I've used CAT6 cables
I've tried different ports.
I've the newest firmware 5.4.2.33
Maybe I'm missing something in the configuration.
schumaku
Mar 24, 2019Guru - Experienced User
Any corporate security on that uplink port probably?
- pryncypalkiMar 24, 2019Tutor
No, I don't think so. It's really strange because I have got some unmanaged switches and those are ok. It is really annoying.
- pryncypalkiMar 27, 2019Tutor
Today I've connected GS105 switch in between and now everything is fine. Anyways, is not really efficient to have a switch connected to the switch just because something is wrong with GS110TP. Do you maybe know what can cause the problem? The router that I'm connected with is HP PROCURVE 5406ZM J8697A R
Now I'm quite sure that there is a problem with the switch itself.
I've asked IT team at the company and they told me that the switch is using 100Mbps with Half duplex when I fixed the speed of the port to be 100Mbps with Full duplex.
Now I fixed the speed of the port to 100Mbps with Half duplex and everything works much better, I can transfer the files etc.
Where should I ask for the help? The switch is quite crucial and I have to fix the problem.
