pryncypalki
Mar 24, 2019Tutor
Problem with full speed of GS110TP
Hello all,
I have a problem with the speed on the first port of the switch. I have to fix the speed to be able to see the device. If I will set the port speed to AUTO mode then the device is not vi...
pryncypalki
Mar 27, 2019Tutor
Today I've connected GS105 switch in between and now everything is fine. Anyways, is not really efficient to have a switch connected to the switch just because something is wrong with GS110TP. Do you maybe know what can cause the problem? The router that I'm connected with is HP PROCURVE 5406ZM J8697A R
pryncypalki
Mar 27, 2019Tutor
Now I'm quite sure that there is a problem with the switch itself.
I've asked IT team at the company and they told me that the switch is using 100Mbps with Half duplex when I fixed the speed of the port to be 100Mbps with Full duplex.
Now I fixed the speed of the port to 100Mbps with Half duplex and everything works much better, I can transfer the files etc.
Where should I ask for the help? The switch is quite crucial and I have to fix the problem.
- schumakuMar 27, 2019Guru - Experienced User
The confirms my suspicion. Reads like a rare interoperability issue of the autonegotiation between the business switch and the GS110TP. Christian_R ChristineT - an interoperability problem NTGR engineering has to look into please.
- pryncypalkiMar 27, 2019Tutor
Thank you very much for all your assistance schumaku.
I look forward to hearing from you soon.
Have a good one
As I'm not Netgear there is not much more than put in some references, have dropped a message to the product manager, too.
