pryncypalki
Mar 24, 2019Tutor
Problem with full speed of GS110TP
Hello all,
I have a problem with the speed on the first port of the switch. I have to fix the speed to be able to see the device. If I will set the port speed to AUTO mode then the device is not vi...
MrJoshW
Mar 27, 2019NETGEAR Employee Retired
I've attempted to re-create this issue on my setup. Using a BR500 and connecting to port 1 of my GS110TPv2. At first I selected the port as autonegotiate and link port reports connected with LED lights on port 1 blinking normally. Connecting to my NAS on the ouside connects with no impact on transfer speed as described in your issue. Changing the port speed from auto to 100Mbps Full Duplex I do see a performance impact but I would like to review further on why you cannot set port 1 to auto without it impacting the connection.
I see that by isolating the device behind another switch you were able to get the port to set to auto without any impact which may be an issue between the HP device and the GS110. Is there anyway you can private message me your configuration file from the GS110 and I can load it to my switch for further testing?
schumaku
Mar 27, 2019Guru - Experienced User
MrJoshW it's an interoperability issue with the auto negotiation between the GS110TP and some enterprise class switches. Manually bringing both ends to 100 Mb/s does mitigate (well, to 10% of the data rate). No need to test with configs - unless you have similar switches at hand for testing.
