milp
Dec 16, 2022Tutor
M4300-8X8F stack - firmware upgrade question
My experiance is not that high, please bear with me. We operate two M4300-8X8F in a stack configuration untouched since a couple of years. As I need to add a new stack member (also M4300-8X8F), it ...
DaneA
Dec 29, 2022NETGEAR Employee Retired
milp,
I suggest you to update the existing M4300-8X8F stack and the new M4300-8X8F switch in a ladderized manner. First, update the firmware from v12.0.11.8 to v12.0.11.10. Then, update the firmware again from v12.0.11.10 to v12.0.11.11 and so on until you reached the latest firmware which is v12.0.17.10. You can download the M4300 firmware versions here.
After you have upgraded the firmware of both the M4300-8X8F stack and the new M4300-8X8F switch to the latest firmware, you can now add the new M4300-8X8F switch to the existing M4300-8X8F stack.
Be sure to do the steps above during non-production hours to avoid downtime.
DaneA
NETGEAR Community Team
