Twonky
Feb 05, 2018Aspirant
Read GS516TP temperature sensor / replacing fan
The 40mm fan inside the GS516TP is rather loud, even if no network connections are plugged in. It appears if, although being fully PWM controlled, the fan goes up to 100% at the end of the booting se...
JohnC_V
Feb 07, 2018NETGEAR Employee Retired
Hi Twonky,
Welcome to our community!
If it seems that you felt that the switch is faulty as the fans are running 100% even if no device is connected. I suggest you to have it replace first and please open a chat / case online on NETGEAR support and please let them know the status of the switch. If you wanted to manually fix the issue with your switch by replacing the fans, the warranty claim will be voided.
You may check our warranty policy here.
