Yaw_Net
Apr 17, 2021Follower
Routing M4300-8x8f
Hi I'm new to netgear and our company plans to implement a few layer switch in our company network, I have been searching and figure out how to configure it on the switcher, now I stack at core switch routing problem, hopefully can get the solutions from here.
After add default route on core switch 0.0.0.0 0.0.0.0 10.10.10.2
PC_1 172.168.100.3 can ping 10.10.10.1, but add second default route 0.0.0.0 0.0.0.0 10.10.20.2, PC_2 172.168.200.9 cannot ping 10.10.20.1.
If I delete default route 0.0.0.0 0.0.0.0 10.10.10.1 then PC_2 172.168.200.9 can ping 10.10.20.1.
I try to delete all default route and add static route 10.10.10.0/24 10.10.10.2, 10.10.10.0/24 10.10.20.2, both PC cannot ping, may I know what is the issue? thank you.
1 Reply
- DaneANETGEAR Employee Retired
Welcome to the community! :)
There might be a misconfiguration on the settings. It would be best that you to open a chat or support ticket with NETGEAR Support here at anytime.
Otherwise, you may indicate here the settings configured in order for other community members to check it and post their recommendations and suggestions.
DaneA
NETGEAR Community Team
