Dr_Skepsis
Apr 11, 2024Aspirant
Setup of management VLAN for M4300 series
I am trying to have WebGUI access of NetGear M4300-8X8F switches on a local computer which resides a few switch hops from the actual devices. What I have accomplished with Aruba managed switches is t...
Dr_Skepsis
This is getting off-topic, as long as having VLAN 5 present at ports 1/0/1 and 1/0/2 does not affect the main issue. The main issue being I can not access management webgui of the NetGear from a computer connected to the Aruba switch.
Topoloy:
PC --> Aruba edgeswitch --> Aruba coreswitch --> NetGear switch
So, if I try to use NetGear webgui PING to the PC in address space 172.17.5.0/24, I get no reply. Also TRACEROUTE from NetGear to PC comes out totally blank.
schumaku
Apr 11, 2024Guru - Experienced User
So definitively a problem with the VLAN configuration on what makes up the trunk on either side, especially if testing from the same network and the connected IP subnet, breaking the in-band management access.
At the risk I will hear again we are going off-topic, you could always use a direct connection to the Gigabit Ethernet service port out-of-band Ethernet management (OOB) port, or standard RS232-RJ45 and mini-USB ports for a local management console available alternatively - extremely helpful for troubleshooting.
Look, I'm just yet another community member here, not paid Netgear support and participating in the Netgear Community at my own cost and time. Don't hesitate to contact Netgear's https://www.netgear.com/av/services/proav-designsupport/. Good luck!
