jameswiltshire
May 14, 2019Aspirant
SFP module help
Hi,
I need to connect a fibre into our switch which will link to another switch on a different site. Our switch is a M4100-50G-POE+ but i don`t know the other switch as it is in a shared companies ...
- May 14, 2019
The AGM732F can drive up to 10 km single mode fiber (on the standard 1310 nm wavelength*) - and it's compatible with your switch AFAIK.
*you might want to double check this, nowadays WDM (wave division multiplex, as DWDM or CWDM) can span 1490..1625 nm sharing the very same fiber link for many concurrent connections (with multiple "colours"), and SFP modules with the non-standard wavelength are available in the market, too.
schumaku
May 14, 2019Guru - Experienced User
jameswiltshire
That's great, thanks. The fibre is between two building, ~ 0.5km apart, so this will be fine. Just wanted someone to double check i`m buying the correct sfp.
Thanks
