nigelgourley1's avatar
Feb 26, 2019
Simple VLAN between two Switches
Switch 1 VLAN 30 Ports 1/2/3/4 Untagged PVID 30
Switch 2 VLAN 30 ports 11/12/13/14 untagged PVID 30
So port 1 = Firewall
Port 2/3/11/12/13 Client PCs
Port 4/14 cable between switches
Ports 1/2/3 can communicate but not any from the second switch
What went wrong it seems like both ways should work
No ports are members of any other VLANS
 If change ports 4/14 to tagged still no joy
What
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi nigelgourley1,
    It will be better if you can share a screenshot of both switches so that we can properly determine which one is causing the problem.
    Welcome to our community! :)
ProSupport for Business
