dysonp
Dec 19, 2017Aspirant
SRXN3205 remote access for administration
I would like to be able to access the router remotely for administration purposes. As I run a website from this location, I have ports 20 and 443 forwarded the LAN IP address of the server. I th...
- Dec 19, 2017
I solved it.
I added a TCP service for port 4430 and then created an Inbound rule which forwarded that port to my router LAN IP address on port 443. I can now login remotely from my browser with:
https://<IP address>:4430/scgi-bin/index.htm
michaelkenward
Dec 19, 2017Guru - Experienced User
Have you been through the steps laid out in the manual?
There is a manual for the SRXN3205 somewhere at the end of this link:
>>>> SRXN3205 | Product | Support | NETGEAR <<<<
See pages 9-9, 1-5, 2-15 etc.
Maybe you have done all this. It isn't clear from your message.
