Mike22359
Feb 03, 2021Aspirant
Static IP Setup Question
I am a pastor of a small church tasked with setting of a live streaming system. I am trying to build something we can grow into and was recommended using a GSM4210p. We want to use the switch to pow...
schumaku
Feb 04, 2021Guru - Experienced User
Hello Mike,
Welcome to the Netgear Community!
No worries, that's a little bit a steep learning curve to bring up the first managed switch - you will manage it, look here...
I think the easiest way would be using an in-band port - without the switch connected to any other parts of the network
Configure your computer with a static IP address:
• For access over an Ethernet network port, use an IP address in the
169.254.0.0/16 subnet. For example, use 169.254.100.201.
The point is that most modern desktop OS will automatically use a ZeroConf address from this 169.254.0.0/12 network (unless there is a DHCP server or it's configured to a static address), so there is typically nothing to configure. Check the adapter IP address at this point - you can direct launch a Web browser and access the switch as shown on this 169.254.100.100 default IP and the QSG.
In case you insist to do a manual config, use for example this:
In-band.
IP Address 169.254.100.201
Gateway 169.254.100.100
Subnet mask 255.255.0.0 or 16 bits
Primary DNS 169.254.100.100
You can direct launch a Web browser and access the switch as shown on this 169.254.100.100 default IP and the QSG.
OOB (out-of-band port):
For access over the OOB port, use an IP address in the 192.168.0.0/16
subnet. For example, use 192.168.0.100.
IP Address 192.168.0.100
Gateway 192.168.0.239
Primary DNS 192.168.0.239
In either case, untick any controls to automatically check the config.
You can direct launch a Web browser and access the switch as shown on this 192.168.0.239 default IP and the QSG.
Happy networking!
-Kurt
Mike22359
Feb 04, 2021Aspirant
Kurt,
Thank you!
I will give this a try this evening. I will let you know how it goes.
Mike
