samarthengineer
Apr 18, 2026Aspirant
Suggestion for L3 switch
Hello everyone, I am designing a new office network with Netgear devices. Check the network topology below. My design will have VLANs. For access layer, I have planned GS724T and GS724...
samarthengineer
Check the attached topology file.
Apr 18, 2026Guru - Experienced User
samarthengineer wrote:Check the attached topology file.
Attaching from your PC doesn't work (forum bug).
Easiest path is to put the topology file in cloud storage and put the link in your post.
- samarthengineerApr 18, 2026Aspirant
https://drive.google.com/file/d/1MrttI8MYT1zb67keMC--iyaXbq8usbj7/view?usp=drive_link
Check this topology file.
- StephenBApr 18, 2026Guru - Experienced User
You need to change the permissions so anyone with the link can download.
- samarthengineerApr 28, 2026Aspirant
Hello sir,
I have configured it with proper permission on google drive.
regards
Sagar Patel
