alarmologist
Apr 06, 2020Aspirant
Summer Time / Daylight Saving Time
Hi, In the Summer Time Configuration of my M4100-50G-POE+, XS712T and M7100-24X switches when I select Recurring USA the Begins At and Ends At settings are not configurable, as expected, but sta...
DaneA
Apr 09, 2020NETGEAR Employee Retired
Welcome to the community!
I haven't found any known issues with DST or time settings for my models by Googling, is there a better place to look for know issues on netgear.com?
As far as I have checked, there are no issues logged pertaining to DST or Time Configuration on the M4100-50G-POE+, XS712T and M7100-24X switches.
In the Summer Time Configuration of my M4100-50G-POE+, XS712T and M7100-24X switches when I select Recurring USA the Begins At and Ends At settings are not configurable, as expected, but start and end both display the first Sunday of January. Is this expected? DST starts in March and ends in November. Will it actually adjust in the correct months?
When I select Recurring I can select the correct months, but I just want to confirm I understand the Offset field. I should enter 60 to set them one hour ahead? I found a description of the Offset field in the manual for the XS712T, but not the other switches, they appear the same though.
Let me inquire these and I'll post an update.
My M4100s are on firmware 10.0.2.20, my XS712Ts are on 6.1.0.34, and my M7100-24Xs are on 11.0.0.10
It would be best that you update the firmware of your switches to the latest version. Kindly access the links below to download their respective latest firmware versions:
M4100 Firmware Version 10.0.2.35
XS712T Firmware Version 6.1.0.36
M7100 Firmware Version 11.0.0.40
DaneA
NETGEAR Community Team
alarmologist
Apr 09, 2020Aspirant
Hi Dane,
Thanks for your response. I decided to just try the manual Recurring settings, the offset field for the M7100 and M4100 is the same as the XS712T, it's set in minutes. All my switches are in production, so I'm very careful even with settings that aren't usually of much consequence.
Now I have to read all the release notes of the intermediate versions of firmware for those models, a GS752TPP and a stack of M4300-52Gs to make sure I understand how we will be affected by anything that has changed.
Thanks,
Emanuel
